I just wanted to say while, these are somewhat annoying, and the risk of burning your coax shield (and your hand) is relatively high. They are far less annoying than crimp on connectors, especially with LMR-400 and the braid ends fraying all over. Though after doing two just now, I think the next time I do them I'll take George Thomas's advice (W5JDX) and use rosin flux on everything. I only had a chisel tip iron in 100w format, I think I'll invest in a chisel tip for my 60w next time I do this because 100w really is just WAY too much heat I think (the outer jacket on one side melted a tad, which was my first hint). I have the tools for the crimp type (had them since forever ago) but this was my first crack at the solder type and they are much easier to do I think. Just make sure your connectors are silver plated, and you tin the braid and the conductor before you start. Don't use the cheap Radio Shack ones, you want Teflon insulators so they don't melt and if your connector is silver plated it'll go much easier.
