PL Tone Scan
Defib
Hello
I have followed instructions to scan ctcss tones for the baofeng uv5r namely:
Menu 11
Whilst transmitting from other radio i must hit scan
Nothing scans
Any advice?
nd5y
Wichita Falls, TX
Push MENU 1 1 MENU *SCAN while the squlech is open.
Don't hold *SCAN for more than 1 second like you do for memory and band scan.
For DCS it would be MENU 1 2 MENU *SCAN
Defib
What indication of scanning will i see because its not doing anythung6
nd5y
Wichita Falls, TX
The display should show R-CTCS on the top line, the CT icon flashes and it automatically scrolls through the tone frequencies on the bottom line until it finds the correct tone, then it stops searching and CT stops flashing.
What radio model and firmware version do you have?
Maybe your firmware version doesn't have tone search capability.
KC9HI
Hello
Menu 11
Nothing scans
Any advice?
On the latest firmware you have to set menu 10 (R-DCS) or menu 11 (R-CTCS) to something besides OFF before CODE/TONE scanning will begin.
Jim KC9HI
Defib
FW297 .... i transmit from unit and keep channel open, menu 10 for R-CTCSS and put it on the first value and hit scan once. Just a beep. No other movement
KC9HI
Menu 11 is R-CTCS.
You have to access menu 11
[MENU][1][1]
Then open menu 11 for changes
[MENU]
Then at this time you can scroll through the tones using the [^][v] arrow keys. Arrow to any value besides OFF. DO NOT PRESS [MENU] to select it. The menu must remain open.
Now quickly, before the menu times out, tap the [*SCAN] key. The cursor (black triangle) in the left status display will start flashing to indicate that the radio is searching for CTCSS tones. Now transmit with the radio that you are trying to get the tone from and you should see the radio start scanning through the CTCSS tone values.
Jim KC9HI
Defib
I have done this exactly how you have put it. None of the tones move it stays on the tone.
KC9HI
Scratch that. Works like a charm. Ever grateful, thank you[emoji3]
Ok. I did try it on my latest radio and I noticed some differences from what I stated above.
It is the CT (or DCS) that flashes to indicate scanning, not the black triangle.
Also, it appears that for this to work, the radio must be in VFO (frequency) mode.
And lastly, you do have to select the the tone setting (anything besides OFF) by pressing [MENU]. If menu 14 is enabled you will hear "confirmed". Then you must open menu 11 again by pressing [MENU] and now you can finally initiate scanning.
Quite a bit different than how it worked when it was introduces roughly 3.5 years ago.
Jim KC9HI
Vicreo
Cd Juarrez Chi, Mexico
Jim KC9HI
thanks jim that work with my f8-hp
