Placing Trunked into NX-300-K2
Nysff
Alden, NY
I have conventional and trunked abilities on this radio as well as P-25. I'm new to the programming software and this will be my first go at adding trunked to my radio. My question is what's the easiest way to merge the info from Radio Reference, into the KPG-112DK Software.
Any Help Is GREATLY Appreciated. And this is for Erie County, NY, BTW.
Echo4Thirty
Spring,TX
I will assume you already have the appropriate system keys, RID and permissions. There is no way to import directly from the database here. The system parameters and talkgroups will have to be manually entered with building the template.
kd4efm
EL98 Florida
The radio is now a 5320, and no nxdn ability once it is upgraded to P25.
Kpg 112 will require a SKF from the system owner to be able to program any p25 info.
Also note, the radio will not do NAS!
