pleasant valley state prison trunked system HELP
#1
Ok i live in coalinga CA about 5 mile away from pvsp i looked up the prison in thhe database and found three frequencies 860.26250-858.26250-859.26250. with the first frequence i get the loud sound and it say CNTRL. with the other two freqences i can hear communication in the wall.
My question is the hole prison is only communication with theas three frequence.
All so when i do pick up talking a 5 digit number will come out on the bottom do i need to put these number in my sccner to pick up more frequence in the prison.
please any help with this wolud be appreciated.
Ames, IA
#2
Seems that it's a Motorola Type ! system those may be the only 3 frequencies used. Fact is you really only need the one in Red which is the Control Channel.. Problem is to track correctly your going to need the Fleetmap for that system, which the database doesn't have.
Hopefully someone in CA regional forum or even in this one can help you get the system programmed in correctly.
#4
HELP please
when i became a paying subscriber i thought that i would be able to download the pdf trunked system which i thought was more frequencies and everything i needed to trunk the prison but was dispointed to find the same three frequencies. in the downloadable pdf for
Coalinga CA 93210
please HELP ME get this system up and running.
#5
not true, it depends what scanner they have. try the fleet maps from other cdc systems, i think they are all the same
inigo88
California DB Admin
San Diego, CA
#7
By viewing all trunked systems within the database for California and looking for systems that say "Prison"...
#8
rene559 said:
where can i find a fleetmap for other cdc prisons
What scanner do you have? I suggest reading the manual. It will probably help you figure out a lot of things about the operation of your radio as well as how these things work.
#9
i found this from avenal state prison .
what do i do with this.
System Fleetmap
Type B0 B1 B2 B3 B4 B5 B6 B7
Mot D D D D D D M M
TT S4 S4 S4 S4 S4 S4 S12 S12
#10
System Fleetmap
Mot D D D D D D M M
See above
#12
#14
rene559 said:
i now how to use the radio it is just this prison and the fleetmap i need help on
Obviously not. You have the frequencies, you have the fleet map, you know how to use your radio, what else do you need help on?
Oregon
#15
Is your scanner a trunking scanner. If not you will not be able to follow the trunking system. You also need to live with in about a mile to a mile and a half from the prison to pick up the transmissions. As it has been asked in the other responces what scanner are you using? Can it be programmed using your computer and software? If you can use your computer to program your scanner I suggest you use it.
#16
It is a pro95 radio shack and i am able to pick up the trunked system just wondering if the three frequencies in the database is all i need and would the avenal state prison System Fleetmap would work for pvsp.
#17
Are the frequencies in the scanner in Trunk Mode? If not, that could be part of the problem, since you should not hear the control channel when the frequencies are in trunked mode.
#18
yes...
Oregon
#19
Because I feel like a nice guy I will give you a possible fleet map for this prison. I know that it works at some other facilities.
Try E1P4
It should read
Block 0 and 1 S12
Blocks 2-7 S04
Hope it helps.
