Please avoid article fragments
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Recently a couple of folks have put fragments of articles - that is, one section in one article, another section in another article. This kind of fragmentation creates nightmares for maintenance in the long term, and is very messy to boot - please avoid doing this. I have no issues with building stubs for long articles - but as stated in the user's guide, please put some text in there to indicate this is a stub. I have usually combined the fragments into one that can be easily edited and changed.
Also I have noted some links to websites (ScanPEI in this case) in an article. This link already exists in the collaboration page for Prince Edward Island. This is another example of fragmentation, since the website exists in more than one place. Please try to avoid this as well for the same reason- long term maintenance. You can check the collaboration area yourself to see if the link you have already exists there - just hover your mouse over Wiki in the blue toolbar, then select Collaboration from the pulldown. Feel free to add links in the appropriate articles - that's what they are there for.
73 Mike
