qlajlu
Silent Key
If I'm not mistaken should he have his P25 set to auto for apco-25 system. The tables will come from the data stream and does not have to be program right?
That is an excellent observation and question. The .p500 file that bell7 sent to me had trunking tables for a rebanded MOT 800 MHz II system. This was probably interfering with the scanner being able to decide what it needed to do. In the RR Database for the Ohio County PS it shows a Custom Trunking Table (below) and that table was imported to my WIN500 program when I did a test import for that system. I simply had bell7 manually overwrite the trunking table in her program with what the software imported to my program during the test import. Apparently it worked. Whether or not it was needed is a question we all have right now.
Code:
[U][B]Base[/B][/U] [U][B]Spacing[/B][/U] [U][B]Offset[/B][/U]
453.00000 12.5 kHz 8192
