Please help Blue Tooth options for 396?
james812
Jasper (Dubois)
Hello all and thanks upfront for the information!
I would like to listen to my scanner via bluetooth, I've looked around and can't seem to find what I'm looking for. I have a 396 that I would like to listen to.
Please advise what equipment would be needed.
Thanks!
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
Thanks!
This is what I use.
http://www.amazon.com/gp/product/B0038MA11U?ie=UTF8&force-full-site=1
And
http://www.amazon.com/Miccus-BluBridge-mini-jack-Transmitter-Headphones/dp/B002HHLOWC/ref=pd_bxgy_e_img_b
Sent from my ADR6400L using Tapatalk
emscapt9816
Long Island, NY
The headset output of the BCD396XT is too low for a standard speaker. This makes it difficult to hear the radio is a noisy environment. The following items can be put together very simply and quickly, and allow you to listen to your BCD396XT privately AND wirelessly:
Jabra A210 Bluetooth adapter, usually available on eBay;
Radio Shack 3/32" Stereo Jack to 1/8" Stereo Plug Adapter, Model number 274-397;
Any Bluetooth Headset.
Follow the instructions found with the Bluetooth adapter and your particular Bluetooth headset to charge and pair the devices. Once paired, simply plug the Bluetooth adapter into the stereo-to-stereo adapter, then into the scanner. Adjust the volume on the scanner and Bluetooth headset to a comfortable level.
mike_s104
How is this much different than the 2 devices I posted? The 2 I posted will do the same thing but you can use any headphones or even run it into a stereo, pc, or anything else.
wmbio
Cumberland, Md
Cardo BTA II - cellular phone Bluetooth adapter - Headsets - CNET Archive
My personal choice...A piece of double sticky tape to the back, mount the unit to the 396 and a RS headphone adapter as Mike above recommends and your in business.
Pix here http://forums.radioreference.com/uniden-scanners/108388-396t-usb-port-discriminator-bluetooth-mod.html My set up is the 5th pix down and I use an over the ear headset and put the scanner inside my jacket or use it in the car.
OBTW, to give the 396 full audio volume at the headphone jack perform the same trick used on GRE scanners, connect the antenna shield to the shield of the headphone jack...most folks use a light duty paperclip or wire to perform this trick...several Uniden threads on this trick.
Enjoy
Wmbio
W2PMX
Fayetteville NC
The A210 performs the same function as the transmitter you posted. If you already have a BT headset or earset you don't need the receiver part. Whether you prefer a little thing hooked on your ear or a big headset is a personal matter.
As far as the differences, who knows? There might not be any, or the Jabra might be better or worse. If someone has both we can get a side-by-side comparison.
