Good morning!
I just got a new POFUNG UV-6R handheld radio and I cannot figure out how to get the scanner to scan, manually programmed frequencies that I programmed in to channels. I first, in frequency mode, ( top line of scanner) programmed a frequency for on the uv-6r, the frequency is for one of my FRS radios, saved it to channel #6, turned off the POFUNG and turned it back on. Next I went to channel mode and saw that the channel was there. Then I turn on my FRS radio and could transmit and receive between both radios. I then, in channel mode, set the POFUNG to scan. It appeared to only be scanning channel 127 & 0 (which I did not even touch).
When I pressed the transmit button on the FRS radio, the POFUNG did not pick up the signal or recognize that I was transmitting from the FRS.
I am trying to set up about 90+ channels with different frequencies and have the POFUNG scan them all for signals and or transmissions.
What am I missing here? I read some more of the documentation on here and the manuals supplied through various links but I still can seem to set up even 2 channels that will scan with this radio?
Thanks in advance!
Thanks in advance!
