I am about to go nuts with this CB stuff. I have another thread here about the antenna wiring on my setup. I'm trying to understand what conductor goes to signal and what conductor goes to ground. I know the shielding part of the coax is ground and the center conductor is the signal..
I just bought a new Wilson fiberglass whip with the adjustable tip. I get it home and I'm looking at it..at the base, there is a wire that comes out from under the plastic coating with an eyelet. What is this?
I was under the impression that the base was what made contact with the center conductor (through a pl-259 of course)...and this was the reason the base must be isolated from the mount - otherwise it would ground out..
The question I have is this..what is the wire that wraps the antenna shaft in a helical pattern??? Is this the ground? Is there some other conductor that is inside the mast itself that is connected to the base??
