Other station Trump possibly?
What's required and involved with monitoring them
Russian voice heard from 0612 UTC today on 263.625MHz
Clearly conversing with someone, but other station not heard. Went for quite some time.
This is a downlink frequency channel P17 so probably from UFO F4 or F8 @ 177.8W/171.8E.
Thanks guys for the info! I have a new AOR DV1 on the way, this sounds like fun! Regarding SSB, is it normally upper or lower sideband, or can it be either?
SSB for satcom or other? SSB on satcom has happened but its very rare and would usually be USB.
The Russians know the uplink freqs to our birds so could potentially use them, they also have a few birds of their own with mil air band transpoders but seldom if ever use them. They've (bomber crews) been known to use the NATO ground to air qrf freq when visiting NATO countries with their Bear bombers. So everyone involved, Russian bombers, NATO intercept fighters, and ground control can all hear each other. The russkii milsat freqs were in some satelite book from ages ago, will have to look it up and post them.
Hello. I use this home antenna for satellite reception between 240 and 300 mhz. It is a 50cm satellite dish and in the middle of it I adapted an MMDS TV antenna part. Works great together with dongle sdr v3. hug to everyone.
Looks like an offset dish and the focal point where all the signals are concentrated are at the end of that empty LNA boom. The tv antenna are set at another point in the center of the dish. Usually you can receive most of those sats with almost any kind of outside antenna. But as long as you receive what you want it is ok and serves its purpose.It is a 50cm satellite dish and in the middle of it I adapted an MMDS TV antenna part.
Here is the original antenna base. I only used her top
Ok, I totally agree with you. But even though I know it's not an appropriate antenna, I use this antenna for reception of the 250 MHz band. It may not be the exact antenna, but it works a little. this is one of the videos I put on youtube with that antennaThat looks like a California Amplifier MMDS antenna/down converter. If so I've toured the assembly line for that unit in Camarillo, CA. It receives roughly 2.1 to 2.35GHz and the output to the TV set is 222 to 408MHz. Its antenna in no way will receive the 245 to 270MHz UHF satcom band. If it does at all then it would work on par with using something like a gas station filler nozzle as an antenna.
