DaveDesjardins
Hi, im looking for a portable charger and ups battery backup. Any suggestions? I own a bc125at and a bcd325p2.
Try this:ups battery backup.
Can you give more detail on what you're trying to accomplish? Do you want to support one or both radios at the same time and over what length of time?
A UPS is not very efficient as the inverter alone depletes a lot of run time away from it's battery source.
A better approach would be using a 12V GEL-CELL and a 12V-to-5V converter, along with a small charger. The length of run time would be determined by the size of the battery and you could support the scanner for several hours, days or even weeks depending on the battery. Using a UPS you might expect several minutes to possibly up to an hour.
For the converter something like this:
GEREE Waterproof DC Converter 8-22V To 5V 3A/15W Dual Power Adapter DC To DC Buck Converter Step Down Power Supply Module Car Power Converter Double USB Cable Connector Car Charger 12V To 5V
Amazon.com: GEREE Waterproof DC Converter 8-22V To 5V 3A/15W Dual Power Adapter DC To DC Buck Converter Step Down Power Supply Module Car Power Converter Double USB Cable Connector Car Charger 12V To 5V: Home Audio & Theater
Amazon.com: GEREE Waterproof DC Converter 8-22V To 5V 3A/15W Dual Power Adapter DC To DC Buck Converter Step Down Power Supply Module Car Power Converter Double USB Cable Connector Car Charger 12V To 5V: Home Audio & Theaterwww.amazon.com
I recommend a Battery Tender designed for charging Gel-Cells. A typical charge maintainer for lead-acid batteries often used for car, boat, motorcycle batteries etc usually not work properly with Gel-Cells.
If you don’t have a USB charging port or three in the car, you can pick up something like this and a spare Mini-USB cable. There are a million of them out there, plus hardwired variations.having a portable charger so when i go out i can have the scanner pluged in and run (when im home scanner are always plug in usb)
For the cost of the one you linked ($54.99), you could get one with more than twice the capacity with change left over.
Or get a high capacity USB battery pack.
