Portland Fire SDS-100
BillyGLSFD
Loveland, Ohio
#1
I’m visiting Portland and have my SDS100 scanner and for some reason I’m not picking up Portland FD when using the zip code feature. Any ideas or suggestions? Thanks so much-
Billy
gskroll
Portland, ME
#2
Make sure you have Services (Fire-Dispatch and Fire-TAC) enabled.
Also, you may want to use “Search” rather than “Scan” as I think the info in RadioReference may not be spot on.
Glenn
W1GSK
