BCD996P2: Portland Scanning issues
Petertherock
Maine
#1
So I have a Uniden BCD996P2 that I just got. The issue I have been having is it takes a long time to find a control channel. Once it finds a control channel it operates great. In fact, much better than the Whistler I have.
I live in Saco, so obviously I lose the reception once I get out of the Portland area. But my whistler scanner didn’t have any trouble getting a control channel when I get back into the Portland area.
Does anyone know if this issue is because it’s a brand new scanner and hopefully now it will easily find the control channel when I go into Portland the next time, or is this a setting issue. I do have the control channel frequency programmed in and I have it on the scan instead of search control channel option.
Anyone know about these scanners? I looked in the instruction manual and couldn’t find anything that would explain this.
Sent from my iPad using Tapatalk
CT
#2
How strong is the signal you get on the CC?
It has nothing to do with the scanner being new.
Is the firmware up to date?
BCD996P2FirmwareUpdate < UnidenMan4 < TWiki
What system are you trying to monitor?
Vrigo Super Cluster, Milky Way Galaxy, Sagatarious
#4
Petertherock - I recommend first updating the Firmware then the Database.
In this Transitional Phase of various agency going from Analog to Digital , you will find many systems replaced with P25 phase I and Phase II, and other Digital Systems. having a Complete and Updated Database on the PC and the Scanner is essential.
I update my Scanner Database every Sunday Morning.
Its also a Good Idea to Download the Entire System for an Agency , as opposed to Just Entering the Channels Manually. you might make a mistake or Leave out both Alternate and Backup control channels, or miss some Sites.
aside from that Check the Obvious, check the Antenna that its seated correctly and a Good Connection is made.
and to SET your Squelch Properly, Open your Squelch all the way (Counter Clockwise ), then Scan to a open Channel (Analog) with Static, then SET the Squelch by turning it Clockwise until the Scanner goes Quiet. Your Scanner Squelch is now SET.
garys
Eastern MA
#5
I had to drive up to Portland Wednesday afternoon. On the way back, I was able to hear the Portland P25 trunk south on I-95 past Exit 36. That put me a bit south of Saco, so the signal is there. If you can't hear Portland that far south check the squelch setting and then check your antenna connections.
Petertherock
Maine
#6
I just wanted to make a follow up post that thanks to a lurker in here that messaged me, I was able to find the problem. I had the squelch set to high! The lower the better for squelch setting. Now I can pick up Portland into Saco.
