Portland/SoPo Fire Analogs?
rpurinton
Windham, Maine
I'm guessing there must be analog relays for the Fire Departments?
Trying to listen with an analog scanner.... No luck.
BlackSheepDue
Portland, Maine
Both cities re-broadcast their prime on a vhf frequency which are in the database. You only hear the dispatch side of the conversation on prime though, no ops channels.
jimbois1
Auburn, Maine
Portland / SoPo Analog
154.2050 MHz CSQ VHF Simulcast of Portland FD (from 800 MHz TRS Dispatch Talkgroup)
159.5100 MHz CTCSS 100.0 Hz R VHF Simulcast of Portland FD (from 800 MHz TRS Dispatch Talkgroup)
