Postal code programming automatically into Favorites Lists?
se
Minto, New Brunswick Canada
Hello All.
When I want to program my 536hp via Postal Code programming, is there an "easier way" to put the resulting information into Favorites Lists?
Thanks Sheldon.
Drumbum
Lynchburg Va
There is a video on you tube that I used when I first got my scanner helped me a lot I'll see if I can find
Sent from my VS986 using Tapatalk
jonwienke
More Info Coming Soon!
VA
Check out the menu item Edit | Add Channels On Range. You specify a location, range, and service types, and it will either create a new favorite list or add to an existing list everything within range that matches your search terms. You can then manually edit the list afterwards.
ofd8001
Louisville, KY
I think page 37 of the manual describes a means for doing so.
From the scanner menu, choose Manage Favorites.
Scroll to New Favorites List and hit Enter then follow the instructions as noted in the manual:
Add Current dB Channels – This allows you to add all channels you are currently scanning to the Favorites List.
At Confirm?, press E/yes or .no
Note 1: Any Avoided Channel will not be added.
Note 2: When adding channels from the Full Database, only channels that are inside the set range, and from the selected Service Types are added.
