We'll see how well Sentinel 2.0 works. One of the reasons I downloaded Power Patrol was there were restrictions and data presentations in Sentinel that my old brain had problems processing. I found PP much easier and more intuitive. I'm still dealing with the issue that everything that I add is to "favorites" , not to the database. Just tonight I discovered there are lots of talkgroups being discovered in our statewide system; as far as I can figure it out, they either get sent to Uniden to update back to the RR database, or I create favorites.Up until the multiple favorites option is implemented, that means one favorite for all personal additions. I understand the issue of using third party software to append to a database that is synchronized from another source on a regular basis, but I suspect that that more comes under the terms of use that developers are restricted to..Anyway, Thanks for your supreme effort!!
PS - how about a "consolette" application using the new USB audio/data stream so I can lean back in my chair and use the laptop to surf and control the HP1 at the same time??
