Yaesu: Power problem with ft2900
scanner10
Newfoundland
Hi I have a ft 2900 it will not power up fuses ok but when you connect positive to positive and neg to neg it's like the radio is shorting any ideas thanks
KC4RAF
Davenport,Fl.- home to me and the gators and the s
Too much info left out.
How old is this Yaesu? Where was it before starting to act as it does now? Did you just get this radio from someone and they showed you it worked ok? Give us more infor about the radio if you can.
And what do you mean, it acts like it is shorting? Sparks flying, loud poping noise, etc.
scanner10
Newfoundland
Hey it is not that old may 6 months old it it trips the power supply when you hook up pos and neg to power supply or it pop the fuse if you hook it up in truck no arcing or anything I have google on here it mentions it has a protection diode not sure if that's the problem
jim202
New Orleans region
Many mobile radios today have a large reverse polarity protection diode inside of them. I would open it up and look for a big diode near where the power comes into the radio. Take an Ohm meter and read the resistance in both directions. (swap the meter leads for the second reading) If you get the low resistance in both directions, it is blown or shorted as many people would say.
Next step is to cut one end of the diode loose and see if the radio will power up. Hopefully it is not a surface mount component. There is no guaranty that the radio survived having the reverse power applied to it. But that is why the big diode is there to blow the fuse and protect the radio from some dummy that didn't know plus from negative when applying power to the radio.
Good luck and hope the radio still works. Let the group here know what you found. Then go back to the person who sold you a dead radio and tell him "Thanks a lot".
scanner10
Newfoundland
Happy to say problem solve with the diode tested it with my meter it was open cut one side radio working fine now thanks for all the info the diode actually cause a dead short after it blew
