Power supply for base station
ht396jm
NJ
#1
Good Afternoon....
Looking for a recommendation to power a total of 4 CDM1250 mobiles for base station operation. Astron command post modules are not really an option as the radios will be rack mounted at a desk. I have one inverter now powering 1 radio but I’m concerned about running 4 individual inverters to the same power source. Thanks for the help.
SteveC0625
Northville, NY (Fulton County)
#2
Good Afternoon....
Inverters???? Inverters convert DC to AC. What is the power available? 110 VAC or 12 VDC?
It it's AC, why screw around? I bought three NIB Motorola power supplies for $150.
WTVLCA01DS0
#3
Is there a possibility that all 4 radios could be transmitting at the same time?
What wattage are the radios?
Do you need battery backup?
Does the power supply need to be rack mount?
HummerMike
Abbeville, S.C.
#4
Per Motorola spec sheet, the CDM series can use up to 1.5 amp in receive. A 45 watt Radio could draw 13.5 in transmit. A low band 60 watt radio could pull 17 amps in transmit. With this info, you could have 6 amps draw if all 4 radios were receiving with the volume wide open. But average would be no more than 4 amps in receive for all four. If you only transmit on one at a time, you would need no more than 17 amps for 45 watt radios and no more than 20 amps if you had a low band in the mix. So I would suggest a good quality 20 amp supply would fill the needs.
Mike
W.Babylon N.Y. 11704
#5
If anything i would suggest 50 amp--even if he is txmitting with 1 radio that leaves 3 receiving so 13.5+4.5=thats 18 amps 20 amp is cutting it close to heat up fast
even if he has 2 txmitt at the same time 13.5x2=27amps +3 more amps (2 idel radios)=30 amps Total/ if he got a 50 amp thats more than enough for 4 radios plus a few other 12 volt items to use
