This is a pyramid supply with only 3 amps but it shows a voltage of 21.9 volts. Usually they will show 13.8 volts. Any suggestions would be great. Anything I can check would help. Maybe its fine??? Thanks Ron
SORRY I should have discribed it better. This is an old pyramid PS8K power supply. I hate to toss it out if there is an easy fix. I can't find a schematic for it. Thanks Ron
The idea behind the 12v bulb is to see if the radio settles to an acceptable voltage once the load (the bulb) is applied. If the voltage continues to run 21.9v, you blow a $.50 bulb vs a $500 radio, not that I'd hook any radio to a power supply that can't maintain itself @ a proper voltage, with no load!
If you don't fix it and just carry on putting light bulbs across the output, the next thing to go bang will be the bridge rectifier or the transformer - then it's a paperweight.
