power wire
wildbillx
Cape May, NJ
I am installing my 2055 in my explorer and wanted to know if there is a problem with hooking up the power wire to the cigar lighter wire. I dont use it and it is in the perfect spot. I also want to be able to turn the scanner on without having the car on. THanks
iMONITOR
Silent Key
S.E. Michigan
That's a perfect connection point! Be sure to include the proper fuse between it, and your radio however. The cigar lighter is usually fused at around 25 amps.
