PPL NEXEDGE96 Wide Area TRS
Drexel Hill, PA
#1
While in Emmaus yesterday I found a couple NEXEDGE96 control channels on 451.225 and 461.3875. I found a PPL license with 451.225 on it (KYL340 (PPL ELECTRIC UTILITIES CORP.) FCC Callsign Details) but can't find a corresponding license with the other frequency on it. The only thing close I found for 461.3875 was one for Robert Conway. This system was coming up as Network L264. Here's what I have for it.
Site 23 RAN 23 NL 11 12 22 26
99 = 451.225
Site 26 RAN 26 NL 22 23
444 =
512 = 461.3875
609 =
If anyone can confirm if I'm on the right track here please chime in.
EricCottrell
Boston, Ma
#2
Hello,
You need to find the additional frequencies used at each site and find some more sites. It first appeared the system was using a common NXDN map.
LCN 1 through 400
f = (lcn - 1) * 0.0125 + 450.0 MHz
LCN 401 through 800
f = (lcn - 401) * 0.0125 + 460.0 MHz
Anything 801 through 1023 would be a custom channel, likely T-Band.
However:
444 calculates out to 460.5375, which is licensed to fire departments.
609 calculates out to 462.6000, which is a FRS frequency.
So it is likely they are using a custom map, which will make searching for frequencies more difficult.
73 Eric
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
#3
99 = 451.225
444 =
512 = 461.3875
609 =
You probably are on the right track. A few things I noticed about PPL licenses -- Most of them are non-trunked (but appear to likely be used for trunking). Most VHF-HI/UHF have 4khz emissions designators. They have many recent VHF-Hi licenses.
I'd have to wonder if they wouldn't be using a VHF for some sites and UHF for others.
If you are interested, here is a Google map with all PPL VHF-HI / UHF locations and callsigns.
https://drive.google.com/open?id=1v7ZnLQhX52o4ZPJhyr5hcMa8qFI&usp=sharing
Mike
