PPS Beta04 seems to not accept multiple conventional frequencies in receiving mode
jpolich7
PPS Beta04 is accepting trunking talk groups into lists, but seems to not be accepting conventional frequencies into multi-frequency lists.
At D-3 Protocol List Setting there is no conventional analog choice without having to pick a tone protocol. The instructions at this point say no selection is necessary for CSQ frequencies::
Protocol Type
  • Definition
    Selects the protocol type for the setting item.
  • Range
    You don't need to set any protocol setting if you are only using CSQ channel (carrier squelch)
At D-5 Zone and Channel Setting, there is no "conventional" mode in the Receiving Mode drop down menu. You get an error message if you do not chose a protocol-- but there is no conventiional CSQ protocol to select. You can select only a single analog conventional frequency from profiles, rather than add or delete several frequencies from frequencies entered at D-2 Conventional Frequency list.
Any suggestions?
Webodisk
Silent key.
Virginia Beach,VA
Have you set a knob position for each conventional frequency you want to scan ?
jpolich7
Have you set a know position for each conventional frequency you want to scan ?
Trying to place several VHF fireground tac frequencies to scan at a single knob position.
Webodisk
Silent key.
Virginia Beach,VA
Create a Zone with each frequency you wish to scan at a separate knob position in the monitor mode, Then make a knob postion set for normal scan all of the zone/knob positions will appear on the left84747
84748
84749
