PPS Changes
dough1213
Frisco, Texas
Am about to start rebuilding a PPS with over 400 items in my current entry. Before going through all the typing required, is it possible first to move around items in entry lines or in zones? Have set-up my current PPS over the past three years by continually upgrading as needed. Hours and hours of work.
tvengr
Well Known Member
Baltimore County, MD
If you right click on the zone number, you can move zones up and down. If you right click on a knob position, you can copy that knob position and paste it into any other knob position in any zone.
amys17
East Sparta, Ohio
Your items in tab 5 (the actual entries can be dragged and dropped around. They will still show the number on from that is their entry number, but they can be grouped with the other items that you want them with. Zones can be moved up or down. Individual knobs can be copied to other knob spaces.
BabaDude77
Connecticut
Which PPS are you using ? Current PPS I am using I can save systems and export TGIDs as well as Radio IDs. If I ever need to re make my CP all I need to do is set up the system with the sites and CCs then load the saved TGIDs as well as the radio IDs and I’m back in business.
dough1213
Frisco, Texas
Thanks to everyone for the helpful responses. I'll try to move things around before attempting to start with a new PPS.
mkinkade
Central Ohio
I'm using the most recent version (3-16-29E). How do you export Talkgroups and Radio ID's? Thanks.
