PPS Download - Previous Versions
Forts
Ontario, Canada
Does anyone know of a site to download previous PPS versions? I need to install it on my laptop but I don't want to use the new v4 version. Would like to stick with whatever was current before that.
Thanks!
FishScan
Old version PPS is going away. If you ever plan on updating firmware you will have to use the new PPS.
I understand that. But right here, right now, I have a need for the previous PPS.
Since it is no longer available from Unication, I'd reach out to your dealer, or a dealer if you bought used from a private party, and ask if they can help.
Forts
Ontario, Canada
Well I imagine somebody here must have the installer tucked away in a folder somewhere. I was positive I had it but it's eluding me.
bob550
Albany County, NY
The ability to update firmware is not necessarily an advantage. Reading through this thread shows the troubles associated with firmware upgrades. Version 1.34 was released around March 23rd, and there's still no working replacement. Unless there's a compelling reason to do so, it may be better to stay with the current firmware.
KC4YIN
Kinston NC
Hi Forts.
I found version 3.16.21 on my downloads folder.
Will that help you?
nyscan
While we are at it here is a related question... will the new PPS work with previous firmware, eg. 1.31?
blackbelter
According to Unication website the current firmwares are 1.31;1.33 and 1.34 which will work with the new PPS.However, none of the above firearms are available to upload at this time.
