PPS on Mac using a VM issues
cpg178
I use VMs for all of my Motorola CPS usually with minimal issues. I was able to install PPS on my Win10 VM and make some changes to my programming file. However when connecting my pager to the computer, it does not show up so I have no way to program it. I did install the driver into the VM from the website as well.
belvdr
No longer interested in living
Generally, you need to map the USB connection to the VM.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Which VM?
If you're using Parallels, right click on the Win10VM, select devices , USB & Bluetooth and make sure the pager has a checkmark beside it.
cpg178
I’m using VMWare. The port the G5 is connected to is mapped to the VM. It just does not show up in PPS as being connected.
KI5IRE
Oklahoma City
I had a similar issue a few weeks ago with Parallels where my G4’s would not show up when connected with the USB to USB-C cable dongles. I ended up trying one of the generic hubs similar to the HyperDrive and that was the only way it would read. Couldn’t get it to map.
cpg178
So I decided to give it another shot, doing nothing different than previous attempts and it worked perfectly fine. That’s computers for ya…
