PPS programming help
How do I move a frequency or site from E-3 to E-7? The site is not showing up in the available scan list.
You must set up the frequency on a knob/zone in E-7, each one on a separate knob. After it is set up in E-7 it will be available for a scan list.
RG, So if you don't check the Option for New Zone/ Knob you don't get to use the sites in the scan list.
Thank You for the help.
Not sure what you mean by "check the Option for New Zone/ Knob" but if you don't include them (program them) on a separate knob/zone you can not use it on a scan list.
Nascar18
Southeast Massachusetts
When you import from Radio Reference. You have the check the Option for New Zone/ Knob.
Always learning something new with the PPS SW.
Typically, what I do is put all my trunked/scan/search zones at the top, then create an empty zone and below that add all my single frequencies to monitor in the top zones.
kb9klc
I'm needing to redo mine here due to the way I like to scan and monitor. I travel a bit too much between 3 counties here and I need to refine it a bit. That's a great tip though.
Nascar18
What I do is use Normal Scan in some knob positions and put 6 conventional sites in the position. I just found it strange that I just couldn't add the site directly from E-3.
KB9, Put each county in a knob position then use the zone settings for anything else in that county. I know its a pain when driving to change the zones.
The issue is the frequencies in E-3 aren't set up to receive, are they P25, DMR, Analog, the program doesn't know, but when you specify in E-7 what the frequencies are then they are available for scanning.
kb9klc
One of our counties has different dispatch zones and depending on where I'm at I prefer that dispatch TG and there's 5 if them that cover different departments. Plus I still like hearing a couple of the state police TGs. I need to just create a zone for that county and then do the channel knobs for the different TGs which cover various police departments. Then likely another knob for a general purpose fire for that county.
kb9klc
Has anybody tried the Bluetooth connection in there car with the G5?
I have a 2019 Mazda CX-5 GT.
Be only time I tried it in a vehicle was as a co-workers truck and we got it to connect and it worked ok. None of mine are new enough to have that fancy stuff. This was in a 2016 Ford p-u we got it to connect in. I have used several brands of Bluetooth headsets and , my G5s connected as they should.
