PR860 Programming
ff_emt
704, North Carolina
I have a PR860 that I need reprogrammed and I have had CPS Version 01.02, but whenever I try to read the radio, I get "Error 87
Unable to read
Check to see if radio is connected, radio is powered on and COM port setting is correct"
Help please.. I really need this reprogrammed.
W7FDX
NC Pennsylvania
Are you using a genuine Motorola cable? Have you successfully programmed this radio in the past?
ff_emt
704, North Carolina
No and no.
I've used the same cable on ht1250's all the time with no problem though. Never attempted to program a pr860 till now.
com501
1.05 is the current software version. You should log into your MOL account and update your software from your subscription before you do anything else.
Second, the PR860 does NOT support a ribless aftermarket cable unless you are VERY lucky. You need the correct cable or a FACTORY Motorola Waris Ribless cable.
