preprogrammed V-Scanner lists
big_d_
Is there any way to load a preprogrammed V Scanner list to A WS1065?
I'm specifically looking at VS-15, Northern Ohio and PA.
Was curious, can't seem to find anything in the forums.
Thanks!
jaspence
Michigan
Each V-Scan list can be programmed in much the same was as a regular scan list. When you use Save as to the hard drive, choose VscannerFile under Save as type.
hill
Middle River, MD
I he is asking how to load the file into the scanner to use it.
Hit these keys:
PGM
FUNC
PGM
Then hit F1 under Load. Then scroll up with the up and down arrow keys to V-Fold number you wish to load and press F3 under load.
The scanner will load these playlists and then reboot and then you should be good to scan.
Going forward most likely outdated, since these lists were made a l long time ago. Trunked Radio Systems change something all time, so I am unsure if these are still current.
In closing it's always best to program it yourself and you are a Premium Subscriber, so it's easy with the programming cable and one of the software packages that supports this scanner. You will have to pay a small fee around $30-35 to use the software.
big_d_
Ok, was curious as The WS1065 does not have them loaded, they are not included. when I followed the procedure, they are all empty.
Oh well. lol.
hill
Middle River, MD
Best to build your own scan lists, since the preprogrammed ones are very old and outdated. Very easy to do with software and downloads from this site
You can have the scan lists the way you want them to be able monitor the agencies you wish to hear.
