President Randy FCC Handheld CB Radio Service Menu
niceguy71
Massachusetts
I tinkered with the service menu mods. How can I reset? I hope I didn't mess things up.
I thought it was fantastic that we could change the power also and went in and turned up my power a little... and the modulation... then I started reading about modulation and learned I should NEVER play with anything! Modulation versus power is quite interesting to learn about and nothing an amateur like me should play with. I was going to write down my factory settings .... but stupidly didn't... I too would like to reset my Randy 2 to the factory settings... but as I look, they are all set differently. as the factory uses an oscilloscope and meters to set each radio individually... so I'm in the same ball park as you and won't key up my randy until I can get it on someone's bench that has the right test equipment and knowledge... I may try to ask someone with a new Randy FCC II to look up his settings and copy them... but that will only get it closer to how where it should be.
slowmover
Fort Worth
Well, . . . there’s a learning curve to things.
Were my “mistakes in radio” limited to the price of a Randy that’d be a good thing.
The Trick: is to learn to re-label, “mistake”, to, “ongoing project”.
“Honey, please don’t touch or move that. The Chief Design Engineer has my question before the working group at this time”.
