President Washington 2 button no modulation
EVERETTLANDRY
Baton Rouge, La.
I have just recapped my Washington 2 button 858 PLL and I’m trying to get her tuned out. However, I have an output (slightly over 4 watts) but no modulation. I have gone over all of my work and resoldered a couple spots that I questioned but I still cannot get modulation. I have even changed the C179 tantalum cap and installed an electrolytic of same value as is recommend but nothing changed. I tried clipping D23 but still no modulation. I’m stumped as this has never happened to me before. Also, no ssb output nor PA output. Any recommendations will be appreciated.
kc2asb
NYC Area
Any possibility the polarity was reversed on one of the caps? The polarity markings on the boards can occasionally be wrong, but the caps somehow installed with the correct polarity by the factory. This was mentioned in a video on Mike's Radio Repair channel on Youtube. He said to note the polarity before de-soldering the caps. Just a thought.
EVERETTLANDRY
Baton Rouge, La.
Receive audio is ok? No problems until the recap?
Radio was receiving okay whenever I bought it but the output was very weak. Not taking any chances , I choose to recap the radio because I want a keeper and figured that new caps would help the output.
UPDATE; Last night after rechecking all of my work, I finally got some modulation but it is intermittent. Also the receive is intermittent as well. I plan on going back into each capacitor and assuring that the polarity is correct. If this issue continues, I’ll have to assume that there is a transistor that’s bad and causing this intermittent issue. On to more research and testing.
