Ask your moma
The Federal Communications Commission (FCC) mandates specific power limits for CB (Citizens Band) radio transmitters. You cannot raise the power output of a CB transmitter, use external amplifiers, or modify the unit internally to increase power. The maximum allowed power is 4 watts for AM and FM, and 12 watts Peak Envelope Power (PEP) for SSB (Single Sideband).
Thanks.
None of us knew that (?)
But itās no longer 1956. The amount of environmental noise
alone is a four figure percentage increase in plenty of places. Add
Skip to the challenge at present.
If you really think anyone wants to spend more to get real Citizen Band mobile performance, think again.
An AM/SSB mobile (10M Export) gets the job done. And doesnāt create a problem.
What we know by your comments is that the safety of you and your family while on the road has a low priority.
You wonāt hear what you need, and if you do itāll be too late to act upon it. There are a number of us have gone to pains to explain the phenomena encountered.
The OP and I ā among others ā both make our living from vehicles. In all kinds of weather, and up against all kinds of problems. We
know the foolishness of 4W.
Sorting a radio problem (or system problem) is the topic.
You can take time to read his comments in other posts about the value of the tool once best guidelines are followed. And you can read my threads to learn what matters
and why.
ā Someday it may matter you have the right gear and have installed it the right way. Be glad itās other than basement nerdlings on this forum to ask. Until then, good luck.
š¤
