primary, and simulcast displayed
stephendaae
california
hello everyone. i recently downloaded a trunking system from radio reference by way of freescan. once you download the system to a window it displays the word primary on the left side of this window for san bernardino ca system 9 and simulcast for several other system from san bernardino. once i download this system to my scanner it displays these same words in the scanner window while scanning and i cannot trunk any of the channels or frequencies if i am saying this correctly. how can i fix this issue so i can hear the talkgroups instead of only seeing the word primary or simulcast in the scanner window when scanning. thank you for any help.
stephendaae
captclint
Mountaintop, PA
Welcome to RR. As per the notes at the top of this forum, this is a specific scanner and trunking system question. It should be posted in the CA forum. However, It seemed to load OK for me. It sounds like you did not check any of the talkgroup boxes on the right side of the download window.
To help with further questions, please click on the User CP link above, and edit you details to include your city and state. You did mention in the body of your msg this time, but you will not have to do that again if you add it to your profile. Also, you did not mention your scanner type. This may make a difference in how to better answer your question.
