jimmyo
I know that primary channels are only required on a trunked system, but does adding alternate channels slow down the scanner?
Thanks for the info. I think I'll keep the alternates and control channels for all systems.
Yes, at least on my scanner (pro197). When I'm trying to identify radio IDs, I get more IDs when I enter just the primary control channel and no alternates.
Of course, if they would change the control channel to an alternate, I would't get anything.
That's incorrect. Scanners don't scan through other CCs unless there is no signal or if you set it to.
Now that i've learned so much about CC vs Alt channels. does it matter in what order the channels are in the scanner (Pro-106 using win500). Right now they are not in any specific order.
Since control channels on trunked systems run 24x7, it's very common practice for the control channel to roll on a fixed schedule. Middle of the night is a popular time to do that. The trunked systems are programmed to do this at a set time.
I run a 5 channel trunked 800MHz system. I've set it up to roll the control channel over every night at 1am. This shares the wear and tear on the transmitter and amplifier. I use 4 of the 5 channels as control channels. The 5th channel doesn't share in that rotation, but it is the channel that is used for sending out the FCC call sign. Rules used to be, not sure if they still are, but the lowest channel on the system was the one that the morse code ID was sent out on. This sort of precluded it from being used as a control channel.
Not having all the control channels in your scanner will cause it to stop following the system when/if the rollover happens.
The accuracy of this entire thread relies on its context being limited to Motorola or APCO 25 trunked systems only. EDACS and LTR systems must have all frequencies entered, and every frequency must be associated with the correct LCN.
So on a P25, phase 1, with 36 frequencies, 3 primary, 9 alternate, 24 stations, just put in the 3 primary and that should do it ? I put in all and have no issues.
Putting in all the voice channels won't hurt (but won't help, either, as the scanner will never use that input information for anything
Really? I'm not doubting you since you sound like you're in the biz, but do CC changes (from what I've seen, around 1 MHz or so) really help extend the equipment life?I run a 5 channel trunked 800MHz system. I've set it up to roll the control channel over every night at 1am. This shares the wear and tear on the transmitter and amplifier.
