SDS100/SDS200: Priority
thegmaniac
I can’t find my answer.
I have one channel in my favorites that when they key up I don’t care what channel I’m on, it will automatically switch to the priority channel. I have the P on the bottom but I’m not getting all communications from that channel while I’m on another channel.
this is a conventional channel.
hiegtx
Dallas, TX
You can set how often the scanner checks for activity on any priority channels. While you can set that in the scanner, you can also set it in your Profile in Sentinel.
The scanner only has one receiver. So, in order to check for activity on a channel set as Priority, it has to interrupt the conventional channel it is currently receiving. If you think you are missing too much on the channel(s) that you designated as priority, you can use a shorter interval between checks. But that is going to break up reception on a non-priority channel more often. The length of the interruption increases if you increase the number of Priority channels.
If you use Priority DND mode (the DND stands for Do Not Disturb), the scanner will not check for priority channel activity until it finishes the current channel's traffic.
Bottom line is that you can set the priority interval to a smaller amount of time, but that will increase how often other channels go between checks for priority. So, you can either have the scanner check your priority channels more often for activity, causing brief interruptions on non-priority systems, or use a longer interval time to reduce the number of breaks. You can't check for priority activity more often, so that you don't miss as much of the transmission, without increasing the breaks you'll hear on conventional channels not set for Priority. Pick one or the other. I use a 4 second interval, and have a limited number of channels tagged for Priority. While I might miss a second or two of a priority transmission, I'm not inserting as many breaks in the traffic I receive on non-priority channels.
Note that if the scanner is receiving a transmission on a trunked system, it will not break away to check your conventional priority channels until the trunked system conversation is completed.
thegmaniac
I’m sure but after I what I paid for this I’m not buying another. Thank you.
bearcatrp
Land of 10,000 taxes
Everyone says that until you realize you have multiple radios in front of you. Most folks have one sweet expensive radio and cheaper used ones. You have a nice Digtal radio. Get a analog only scanner for under $200 and sometimes under $100 if you come across a sweet deal. Unless you have a short list of frequencies to listen to, your missing out on transmissions.
ofd8001
Louisville, KY
Unfortunately there isn't a radio, be it scanner or "regular" radio that can remain on a non-priority channel while checking for activity on a priority channel. It is the nature of the beast.
Throughout my fire service years (getting close to 50), I've used Motorola radios from Mocom 70s up to APX models. Even they stop receiving on Channel A to check for activity on the Priority Channel B. (Super noticeable when two tone paging is involved.)
So what we have done if we want to monitor two channels, at one time is purchase a second radio for the apparatus/vehicle.
doc62
Thanks for the info on how the SDS100 handles priority.
I have both the SDS100 and a Unication G5. The G5 does a great job on handling varying levels of priority. For example Fire Response has highest priority then my station's channel then police dispatch. In all I probably have 6 channels in my stacked priority list. Of course the G5 is a different beast than a SDS100 and I'm only use the G5 for my county.
n1chu
Farmington, Connecticut
I’ve been listening to a first responder receiver since I was a young boy back in the 50’s-60’s. My town’s vol FD used sirens to alert the members. When that siren sounded, everybody wondered where the FD was headed, especially during the spring and fall when brush fires were abundant (outside burning was allowed, people burnt their garbage, yard cleanup debris, etc.). My first radio was a Realistic Patrolman tunable VHF Low band 30-50 MHz. Both my town’s FD & PD were on this band, but I had to tune between them manually. When Regency came out with a crystal controlled 4 channel scanning radio I was in 7th heaven!
The entire county was using a single frequency for Fire Dispatch, no PL’s, with little or no FG secondary channels. But because of the “party line” usage, the county frequency became crowded to the point where individual FD’s moved off of the county frequency to their own VHF Low band frequency, or up to the UHF Band, where they not only enjoyed a quieter dispatch frequency, they pretty much eliminated the interference caused by band openings (skip) that was prevalent at the time on VHF Low band. And then Regency came out with a VHF/UHF scanner… basically two radios in one, with 2 crystal controlled, 4 channel boards. It worked out nicely but the “missed transmission” problems were beginning to become apparent. It wasn’t a problem for me because I kept my 4 channel VHF Low band scanner and the Patrolman tunable receiver, running all 3!
A neighboring mutual aid town went to UHF which caused a problem when conducting mutual aid calls but I suggested as a temporary stop gap method we install single channel monitors aboard the apparatus on our vehicles set to the frequencies of our mutual aid friends, and the neighboring towns do the same. We could listen to them on their frequency and they could do the same on our frequency, cross channel talk. That worked for a while but it wasn’t long until the radio shops started offering dual band radios, or carrying a portable radio tuned to our mutual aid friends frequencies.
Today, the county doesn’t use the old county VHF Low band frequency (with a few exceptions). All county FD’s have their own assigned frequencies with mutual aid concerns being handled using prescribed channels and/or “patches” with common PL’s, on their conventional VHF/UHF repeater-ized systems. But it didn’t stop there… now there is a P25 statewide trunked system that is available to all PD & FD (among other agencies). Yet another option on an entirely different band. This means that between all the conventional VHF/UHF systems and the statewide trunked system the need for additional receivers is a necessity if you don’t want to miss anything. Getting a second and third receiver, and dedicating them to the agencies you are most interested in is a must… just like I learned when early on, I kept my first tunable rig and VHF low band 4 channel scanner, playing along with the new dual band VHF/UHF Regency scanner! I kept up with the times and today I enjoy monitoring with the purchase of a couple of SDS200’s and a SDS100… and I still miss a lot!
(The trip through the years, with all the scanner offerings was fun though. I still revel over the introduction of the PRO 2006… a drastic improvement in reception quality over previous scanners made it my most memorable, and enjoyable upgrade ever!)
The old saying “The more you scan, the less you hear!” is now more apparent than ever!
a417
If it's a single conventional frequency, you can buy another reciever or analog scanner. Hell, you could buy a baofeng for $20 and use that. Used radios pop up on craigslist & ebay all the time. Ball is in your court.
