Private Ambulance Frequencies
Cleveland Heights, OH
#1
Does anyone know the frequencies for private ambulance companies in Cuyahoga county other than the ones already listed? I am particularly looking for Physicians Ambulance's Frequency(ies).
#2
You might check the Vincent Bak LTR system listed in the database for Cuyahoga county. They are mentioned as a user.
jdolina
Lorain Ohio
#3
I found an LTR system on 451.8750 I believe is LCN 2. I was getting hits from 0-02-010 which were from physicians ambulance. It may be part of the vincent bak system although that frequency is not in the fcc database for it. I have not researched it more.
