Private radio ID's on 800
Kel
SW 2-18-26-W2
Programmed radio ID 2241795 as Engine 1 and now it displays ID 13571 0n EZ Scan software,do I have a setting on General or Advanced settings set wrong?(Private radio ID).
Kel
SW 2-18-26-W2
If I use the last 5 digits it will accept it,any advise on this have yet to try on radio yet.
robschonk
Avon, NC
If you update the database, there's a box to uncheck so you won't update the alpha tags. Wonder if it does the same thing for TGID's
