Pro-106 Advanced Priority Setting
nzo012
I see in the ARC500 software there is the setting for priority checked, it looks to be default at 20. So, it checks the priority every two seconds. So if I change that setting to 10, I assume it will check the priority every one second. I noticed on the actual Motorola and Macom two way radios the priority is checked much faster, almost like two or three times a second where it sounds like a rapid tapping, rather than an audio cut out every two seconds.
Is it possible to get the PRO-106 to check the priority more frequent than once a second?
M105
If 20 = 2 seconds that implies that the number is in 1/10th second increments. If you want it to check every 0.3 seconds, put a 3 in the box.
