bscout
What kind of battery life are you getting on nimh or nicad batteries? My 106 gets a lot less run time than my PRO-97 using the same set of batteries. Thanks
Ok, I run POWEREX NIMH batteries (the best I believe), and discharge the fully each cycle, at which point the spare set goes in. I use LOTS of backlight, and of course am a complete scanner geek who takes it everywhere, and at worst I change them out once a day. I have forgot the backlight before, left it on all night, and it was still going when I got up, light on.
For what you would spend in a few weeks of alkalines, you could buy the low end conditioning charger and two sets from thomas distributing and after a few weeks you would begin saving the money.
http://www.thomas-distributing.com/index.htm
For most companies that number is rather a gimmick, like contrast ratio on flat panels. Maha has released a statement that their numbers are accurate, and that they refuse to take part in the game, and that 2700 is what is possible given current battery technology in AA size. They stand by their claim that their batteries will outlast others claiming greater numbers, and I vouch for them. Camera geeks who go through batteries like water swear by them, google "best nimh camera battery".
There are different ways to arrive at that number, kind of like GMRS radio makers claiming "15 mile range" or "25 mile range", its just hype all too often. The maha batteries have the rep to back up their numbers.
I was going to do a post on this. I get about 16 hours or so with my RS 2100mAh rechargeables. I luckily have two sets so I can charge one while operating with another. I don't use the back light often, if at all, but my talkgroups do use the LED. I think I will purchase the 9v adapter for use at home, and pop the batteries in for mobile use. I also think I'll get a better charger. I just purchased the cheap $20 RS one.
One thing, I have the battery setting under Alkaline. I found that the scanner would alert to low battery a lot sooner under the NiMH setting. Is there any harm in doing this?
