pro-106 Digital Trunking
Brandon91
Ionia, MI
I own the pro-106 scanner. I only listen to the county I live in which is Ionia. And on the 800 band I don't know y but it garlbes sometimes, dispatch and the cops call it "going digital" I watched a You Tube vid and it said that it's called encreption. So what is it called? I did have a clerk at Radio Shack trunk them for me but I don't like it because the T flashed. I have them all stored as CONV and I have the search turned on and displaying on the unit (the one it shows either DCS, CCTS, DEC, P25, ect.) I don't really know how to "trunk" the 800 freq.'s either.
rmiller818
Marietta GA
If it sounded garbled to you and the person they were talking to says "you went digital" or something to that effect then they probably heard the same thing as you did and it is due to a weak signal from the person trying to talk. If you just hear garbled noise all the time it may be encryption (check the database and see if that talkgroup is marked as using encryption)
