Pro 106 heap error
case8245
When I try to use the keys on my scanner like the PGM or MAN, I get a "heap error 220D1F : 2214" message. How can I fix this? I can program my scanner on my PC, but can't lock out by just the key pad.
RoninJoliet
ILL
You have "NOT" assigned some trunking TG's to the actual trunk system, by hand you need the "*" on the proper ScanList along with the correct Trunk System when you associate the TG object with the system....
case8245
Thank you for your help. I do not understand what you mean by assigning the TG by hand with "*". I don't know how to do that. When I press the buttons on the scanner I get the error. On my computer all TG are assigned.
RoninJoliet
ILL
When your monitoring a trunk system and you see the TG's pop up hold on them and watch the "text" flashing from talkgroup text to trunk system text, one of the TG's will say "no trunk system", because you did not assign it properly to that trunk system, thats what causes "Heap Error.....When you program the scanner by "hand" which i do and assign a TG to a trunk system the SList must have the "*" astrisk present to match up the TG with the trunk system....There are many other posts on this site that have seen this same problem....
kendrik578
Live Audio Administrator
Greensboro, NC
You will first have to clear the scanner completely Quick taps of 0, 1 during power up then do as Ronin described.
md_p97
Barnesville, Maryland 20838
I had a similar issue with my PRO-106, just before it stopped working properly.
After the scanner using the same files (and I do switch the loaded files from time to time) for over a year, I suddenly started getting heap errors...I tried the "0" then "1" at startup, reloaded my files and that seemed to do the trick for about a week.
Then, out of the blue, my scanner would no longer work with the ac/dc adapter plugged into the side. Neither the one I use in my truck, or from the wall wart at home. But interestingly enough, it works just fine when running on the alkaline batteries alone.
Not sure if its related, but after the scanner using the same file for well over a year, it makes me wonder...
GumbyCT
NH Cty, CT
You have a completely different problem....I think.
Read this - http://forums.radioreference.com/radio-shack-scanners/168822-voltage-level-pro-106-question.html
If it turns out it is related - please do let us know that.
Good Luck
ind224
Indianapolis
Is there no way of clearing a heap error without losing all programming
I just flashed a new hard drive and do not have back up files.
It find it odd the hand programming allows you to create a tg without
a system and this trashing the scanner until you flush it. Actually I find it quite
it quite stupid in design. No prompt to say "do you really want to disable your
scanner and lose a your settings?" instead it says new tg like no problem.
W6KRU
Vista, CA
You don't have to clear all programming. Just find the TG in error and assign it to a TSYS. Details here: PSR-500/600 Heap Errors - Powered By Kayako SupportSuite
ind224
Indianapolis
Good news. I thought I bricked the radio until reflashed because I was in the field with no way to get around the heap error. 0 1 did restore the scanner without killing the V folders which is what I was fearing. When someone says clear the scanner "completely" by doing 0 1 I assumed this would take out the V folders. Unacceptable. Thankfully that did not happen. :wink:
