Pro 106 help...
bahand
Little Rock, Arkansas
Hey guys,
I just bought a new Pro 106 and am trying to program it. I'm attempting to program the city of Little Rock public safety. They are a Motorola type II smartnet. I have gotten the 800mhz freqs in but now I'm trying to put in all the Id's. I can only put 1 in. Can you put more than 1 in? And if so, how? By that I mean like entering fire dispatch, and then all the fire ground channels. I don't want to listen county wide to every entity but I also don't want to listen only 1 ID. I really miss the simplicity of my pro 97.
Thanks, Blake
jfhtm350
New Market TN
Yes you can put more than one talkgroup in a trunking site.
Are you trying to program it by hand or are you using the programming cable and some software?
The decimal number is the talkgroup number. I dont know what Subfleet 0 is.
VE3JSO
sarnia ont
by hand the easiest way is use the wildcard instead of the talkgroup id and then hit store when the scanner finds a new talkgroup or just use the programming software it's alot faster if you have the cable
