Pro-107 Software
SOUTHBAYSCANNER
CA
#1
Is there a way to copy a configuration to the pro-107 (via the iScan software) while the SD card is still inside the pro-107 and not having to physically pull the SD card out and put it in an SD reader?
Every time I choose "Copy to..." or "Copy From..." from the SD Card tab, the iScan software doesn't recognize my card, even though I click "Re-scan."
Also, is there a better program out there, that would let me do this? I ask as I would like to operate my feed remotely and not have to call my friend every time I need to lock-out/add a channel, make a change, etc.
morrisr3nd
Hattiesburg, MS
#2
You can only update the scanner by taking the card out of the scanner and either installing it into a computer directly or using an external card reader.
Your card could be corrupted. Try reformatting it using the software and then copy the files back to the card.
I think iscan is the only software that will work for this scanner.
The only thing you can do connecting the scanner directly to the computer is to upgrade the scanner firmware.
I sure hope this helps. I
