Pro-107 "Stuck" on one Scanlist?
sc8
I programmed my Pro-107 scanner using Win500 software for the Orange County NY EDACS system. The way I set it up was I made a TSYS object for each tower (Beacon, Adren, Graham, Sam's Point, Schunnemunk). I also made each tower its own scanlist. Then I entered in all of the talkgroups and assigned them to the appropriate scanlist. This is the same way I did it on my GRE-600.
The problem that I am having with my Pro-107 is that when I am scanning the LCD display only says "Beacon", even when I turn off the Beacon scanlist. It is acting like none of those other scanlists/TSYS objects exist, and I'm not sure why.
sc8
Yep, thats it.
I figured it out though. It turns out I only set the TG's up for one of the TSYS's.
