sandbender
I have a pro-160 that I am trying to program using the ARC160 software. The system is UC Santa Cruz (University of California (Santa Cruz) Trunking System, Santa Cruz, California - Scanner Frequencies). I can connect to the RR database and import the system and program the scanner, but it never receives anything. In fact, I get a message on the scanner saying there is nothing to scan. The scanner can receive if I tune to specific frequencies so there is no basic problem with receive, just a programming problem.
After import, the frequencies table for the bank is empty. The talkgroup table has all the talkgroups. The Settings table has the following...
Bank Name: USCS
x Bank Enabled
Bank Type: Motorola
o Closed Mode(-)
Trunk Settings:
Mot 800 System Type: Normal (default)
VHF/UHF
Frequency: 406.0000 Offset: 380 Step:12.5
Edacs ID format: AFS
Block0 through 7 are set to "Type 2"
Motorola Options: Control Channel On
I'll also attach a screenshot.
Clearly the system is not loading correctly from the RR database. The ARC160 version is 1.21 build 6 (Full Version).
Any help would be appreciated!
Thanks,
-Pete
Bank Name: USCS
x Bank Enabled
Bank Type: Motorola
o Closed Mode(-)
Trunk Settings:
VHF/UHF
Thanks,
-Pete
