I bought a PRO163 the other day and performed my usual mods:
I installed a Discriminator Tap using a standard RCA jack with a single wire to the TP-4 common to most Radio Shack scanners.
I also installed a Size "M" coaxial power jack to the rear panel. Since most of my other scanners all have this connector I like to standardize on it. I have equipped my various RS scanners (2 Pro2096's in the current shack) as well as other devices such as my several CD-1 decoders with this jack.
Both of these jacks were installed on the rear panel of the radio by drilling a simple home (1/4 inch for the RCA jack, 5/16 inch for the power jack) and then running a single wire to the proper place on the board. The power jack was connected to the reverse polarity protection diode near the existing power jack while the discriminator was run to the usual TP-4.
The radio seems to work well so far, I have been using it mostly for searching the aircraft bands. I am getting a little broadcast interference on the upper reaches of the UHF aero band but not more than any other radio.
