Pro-163 Ottawa EMS EDACS
Ottawa, Ont.
#3
Rebanding does not apply to EDACS, only 850MHz Motorola systems.
The PRO-163 can be programmed for the EDACS system. Be aware,
these are special-purpose EMS channels used for events etc. including
Winterlude. Main EMS activity is on Ontario-wide Motorola VHF system
which you can also receive:
Bell FleetNet - Ontario Provincial Government Zone 2 Trunking System, Southeast Zone, Ontario - Scanner Frequencies
In case you're not aware: forget Ottawa Police on EDCAS on your scanner (or any other); but there are other ways to receive
them.
Dave
Ottawa, ON, Canada
#4
Thanks for your replies !
I was listening to the below feed thru the net and if I can receive Ottawa EMS and a few things that would be great !
Ottawa Public Safety
Feed Notes
This scanner feed is set to follow:
  • Ottawa OPP (2OPS37, 2OPS34, ONLY)
  • Ottawa EMS (Alpha, Bravo, Charlie, Delta)
  • Ottawa Fire including Airport Fire
  • The scanner does not broadcast O.P.P TAC talkgroups or TAC EMS talkgroups
The scanner has been re-programmed to stream line the scanner activity for the Ottawa Area.
The current reception location is Ottawa West.
