PRO-163 Trunking
mkwallac2
Zionsville, IN
#1
After setting up the pro-163 for trunking, I only seem to receive static and/or the "motorboat" sound when scanning stops on TGIDs. I've done extensive reading and believe the scanner has been setup correctly manually. I also programmed another bank using the win97 software thinking perhaps i missed something manually. Below are the details to help identify
-Trunking System is Indiana Hoosier SAFE-T System (Specifically Boone County Simulcast, IN).
-I programmed in only the CC 866.73750 and the alternate 867.16250 since all needed for MOT type.
-TGIDs programmed for now are only Boone County (06) Talkgroups
-Link to page SAFE-T paged used just for help is Indiana Project Hoosier SAFE-T Trunking System, Statewide, Multi-State - Scanner Frequencies
Again, thanks and I hope the above is sufficient information.
New Jersey
#2
Boone County (06) TG's are digital, you won't be able to receive them with that scanner.
#3
After setting up the pro-163 for trunking, I only seem to receive static and/or the "motorboat" sound when scanning stops on TGIDs. I've done extensive reading and believe the scanner has been setup correctly manually....
That is a rebanded Motorola system and it can not be monitored without entering Custom Band Plans. I understand it can only be done using software. You will have to search this site for more detailed info.
