Pro-164 fmn?
greatgoogly
Spencer, MA
#1
My local police just changed to 151.325 R D606 which I gather is "fmn", can I listen to this on a Pro-164? Currently I have it programmed in as "FM" as there is no "fmn" mode available to choose. If I leave it at FM will I receive the scanner traffic? Thanks?
greatgoogly
Spencer, MA
#3
The short answer is that you will continue to be able to listen to it.
Here's a thread on narrowbanding: http://forums.radioreference.com/general-scanning-discussion/7148-narrowband-fm-vs-fm.html
Thank you, yes it is working. I seem to have made a simple situation complicated. I had programmed the frequency in using the Win97 software, but I was doing 2 things at once and mistakenly plugged it in as AM, switch it to FM and all is well. Basically an ID10T error on my part ;-) Thanks again.
