I have (2) RS 197 scanners and both perform perfectly here on the simulcast IL 700-800 Starcom State System, even using a outside antenna,.. I am five blocks from one of 18 towers and get great coverage,.. It seems to all hinge on your area and how close you are to other interfering towers,...
Yes it does. You are close enough to one tower that it "drowns out" the others.
Take it for a ride and let us know how it does.
As I told the OP, try it and see. Has the scanner, has the software, nothing to lose other than 15 or 20 minutes programming the system. Perhaps they will win The Simulcast Lottery, as you have done. Chances are they will not.
As I also said, I tried it myself. If I lived where my daughter does, a Pro-197 (or handheld version) would not be an acceptable option for me. Fortunately I have other options.
@slacker668 I should have also mentioned in my last post that there are plenty of *other* things you can listen to with that Pro-197. Yes, most counties in central NY are on P25 simulcast systems, but they all also have a patch to an analog (usually UHF) channel where fire dispatches are broadcast. I programmed in a number of neighboring counties and was able to pick up several of them using a rubber duck sitting inside.
There are also schools, air, rail, GMRS/FRS/MURS, ham repeaters, etc. Many of us who have an SDS or two also have analog scanners to listen to things other than the local P25 system. Using an analog scanner at home with an external antenna, I can pick up Fire and EMS dispatch as far away as Syracuse, Watertown, and Allegany County, depending on ducting. There are also a couple counties that still use analog frequencies for law enforcement that I can hear as well.
