Pro-197 Mobile Antenna
drguitarum2005
Katy, TX
Howdy yall, I recently installed a Pro-197 in my truck to better listen to everything going on the county/city. My radio for the fire department is an old analog radio and everything else is on P25 digital. What would be the best antenna for listening in the P25 (i believe 800 mhz) range? I have the occasional VHF frequency in there for some older systems but 98% of what I listen to is on P25. I bought a 36" magnetic mount but I can't find a place to mount it that makes me happy. Are there any good glass mount or very small antennae that yall would recommend? Thanks!
Rt169Radio
CT
The Larsen tri-band antenna is able to pick up 800mhz.It can do 150-165/450-470/806-940mhz
You can get it here:
AES Price list
The model number is NMO150450800
W8RMH
Feed Provider Since 2012
Grove City, Ohio (A Bearcat not a Buckeye)
I use a Comet M-24S ham antenna that I purchased for ham dual band, but it receives extremely well on 800,154, and 460 MHz. and is less than 20 inches high. It has a SMR connector (HP1,396XT) or you may need a BNC adapter. There are cheaper scanner antennas out there but this is a good commercial grade quality antenna.
Comet M-24M Mobile Antenna M24M
